Ryu James
Ryu James's Avatar
06.13.2009, 06:04 PM
Originally Posted by Matthew_Armeni View Post
You should be able to run the stock Kyosho 2-speed clutch bell on the 3 shoe Tekno adapter. The 1512 should be plenty with the 2-speed, but the lower kv motor will run cooler and still be fast, the on road cars have really tall gear ratios.
i cant get it to work with the gt1 but maybe it will work with the igt2 clutchbell? or are they the same?
Jammin SCRT10 Neu 1512 1y
2-speed
exawatt
2-speed - 06.13.2009, 06:20 PM
just order the 2-speed pinion from rcm it works great and its cheap.
Ryu James
Ryu James's Avatar
06.13.2009, 11:53 PM
i do have that and if i cant get a 2spd clutchbell to work with the tekno clutch that is what i will end up running. thanks.
js058515
Thank You Brushless Gods!
js058515's Avatar
07.11.2009, 11:20 PM
Any updates on this Ryu James? I have a GT2 coming in for track practice and want to do a similar setup.
Losi 8B 1.0, Tekno V3, Direct-Drive, 13/48, RX8, T8 1400kv
Losi 8B 1.5, Tekno V3 w/clutch (3-shoe), 14/48, MMM, Neu 1512 2Y
Losi 8T 2.0, Tekno V3 w/clutch (3-shoe), 14/48, MMM, T8 1550kv
Ryu James
Ryu James's Avatar
07.12.2009, 09:15 AM
no, i wish man. i started buying everything to do the conversion and then got distracted with the 1/5 scale project i am doing now. so that IGT is on the back burner for now. i will devote attention to it again when the 1/5 is done....and i get some more funds....this 1/5 is killing me.
