shaunjohnson
i pwn nitro
shaunjohnson's Avatar
08.03.2009, 05:38 AM
we didnt expect it to place so we went bashing after the final in the nearest mud hole
and umm...we kinda wore out the tyres on it
no not the main tread...THE SIDEWALLS!! the sidewall lean wore out the thin rubber in that location so not it has many holes in the sidewalls
so IF it has to be raced again it's getting talons (yuck)
BTW!!
if you own a summit, switch the T-lock servo's around, so when you lock only one diff...you lock the rear diff rather than the front. this way you get better turning AND you can drift and do doughnuts!!!
