01.20.2010, 10:54 PM
Originally Posted by Jrock2310 View Post
Thanks alot but are u sure it will fit the dm-1 spec cause it says it's for mbx/ gtp
yes sir
ASYSTEMERROR
01.21.2010, 10:40 AM
Just looking for an honest veiw on the DM1 would anyone feel that the novak HV pro system would be good enuff for the convertion ? my DM1 will also sport the single speed and i was just thinking would mid 50's be out of reach for the novak system i want the car to be comparible to a DM1 with a 21 ninja , well a tad faster but i dont want the brute torque just the top end i do plan to race and felt the sensored motor make bring some benifits.
Jrock2310
01.21.2010, 10:25 PM
First off the dm-1 is a great car and depending on your gearing you should get about 55-60 with a 4s but since you changed to a single speed that means you probably have that 51 tooth spur cause I was about to switch to single but I really didn't want all those teeth in my spur. If I were you I probably would go with the mamba monster 2650 if you plan on running 4s..
