Make an offer.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Make an offer. - 01.31.2010, 08:57 PM
Originally Posted by JCUEVAS View Post
I was planning to get two of those heatsinks also
Make me an offer for the heatsink and the 125b. Shoot me a PM and lets make a deal. I am sure that someone will want it, and I am not going to use it. I have too many other ESC's at my disposal MMM, RX8, MGM 120/24, & Schulze 18/97.
As for the caps. I have not worked with the other Quark ESC's, but I am sure that some one will chime in here to help with that. The caps help to smooth out the voltage issues keeping the ESC working smoother than usual. It is a common problem. You may also check out your radio wires to make sure there are no shorts anywhere. If you are using an FM radio and receiver it may help to move up to the 2.4ghz radio gear. Coggin can also be related to the ESC in relation to the pole numbers in your motor. Some are just not compatible. Those are just some of the issues that I have read on here with cogging problems.
SUPERMAXX YOUR LIFE.
