Serum
Serum's Avatar
02.12.2006, 06:12 AM
I don't know the name for it anymore, but there are diodes that create a near dead short if they are above their voltage (available in a large variaty) and ara capable of killing quite some power (peaks) and are really fast.
I talked about it with schulze, because of their 'loose contact' issue, but he put his head in the sand, eversince his controller is the most flawless controller available..
my idea was to use them on the motorside and on the battery side. A rather easy mod. but then his 'loose contact' story wouldn't be adequate anymore..
02.12.2006, 02:20 PM
Yeah, there are several components that do this: MOVs, avalanche diodes, zener diodes, etc. Gotta be careful though, some components (avalanche diodes) actually generate RF noise. Since the motor wires pass AC (I know it's PWM, but it's still AC), maybe a $0.39 MOV would be the best bet. Something with a breakdown rating of about 1.5x the max battery voltage should work fine. And I would just put them across the motor leads since the motor is what creates that back EMF. There isn't anything in the battery side that would benefit so I don't think I'd put anything there.
