shaunjohnson
i pwn nitro
shaunjohnson's Avatar
10.16.2010, 04:48 PM
if you dont run boots you will not need to replace them...but every year or so you might need new carriers.
clean the balls/carriers after a run and put some silicone oil on em and that should be ok.
i only run boots on the rear as that dosent move as much as the front does, minimizing the replacement of the expensive RPM true track carriers relative to the inexpensive front carriers.
Tags
axle carriers, dirt, dust boot retainers, revo, rubber
