littlejohn
12.26.2010, 12:56 AM
Anyone else have this same prob? I just had exactly the same thing happen to me. :(
IGT_7x
IGT_7x's Avatar
12.26.2010, 01:03 AM
littlejohn - what I did to fix the problem was to plug in the ESC & flash the firmware back to 1.24 which worked, you might have to try it a few times & then once it worked I flashed it to 1.28, stay away from 1.29 it never worked for me on any of my MMM. Hope this helps.
littlejohn
12.26.2010, 01:23 AM
Ok... Not sure if it was in a manual somewhere...
But I was using the field programmer as my link interface. It appears that the field programmer was chewing up more power than the USB port could supply, so when the ESC rebooted as part of the flash upgrade, it didn't fire up properly.
I plug in my batt and whilst programming and everything appears to work as it should.
PS. I flashed to 1.30. fingers crossed everything works as it should with 1.30
IGT thx for the reply.
