RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
01.25.2012, 06:23 PM
Originally Posted by Kirkinsb View Post
Based on my experience, I am completely surprised by your max current of 240amps! Especially in a medium sized vehicle. My 28lb Baja 5t pulls 215 amps on pavement with NO tire spin. Meaning I am putting all the power to the ground... That is with the 2028 motor on 8s and running the crap out of it hard.
My Brushless E-Revo (more closely realated to a muggy than my 5t) also with an XL2 and a 1518 motor only pulls 106 amps on 6s...ripple is 1.8v with cap pack. And that is running mine wide-open-throttle...all the time really hard!!! So 240 seem really high to me....especially if you are just blipping the throttle. If I were to guess, I would say your motor is malfunctioning which is what caused your MMM2 to fail. Neither of mine cog in anyway shape or form.
Again, That is just my experience. Your current numbers are WAAAAY higher and different than mine and I have been running my baja 5t for about a year now. I was one of the first owners of the Castle Baja Conversion kit with the original Mamba XL ver 1. I would say you have a problem somewhere.
My XL2s are doing great! Lots of fun now.
Your numbers are low(especially the Muggy). What sample rate are you logging data at? I have seen 200 amps on a 10 pounds truggy in testing with an average draw of less than 30 amps during the run. A low sample rate will mask the true peaks. Also, any punch control or expo settings on the radio can also lower the recorded peak draw.
magicald
01.25.2012, 08:26 PM
The logging is set at default (I'll have to hook it up and check).
All other settings are at default... No punch control and radio is set on linear with no end points.
What's the best setting to change to tell if it's my batteries...if there is a setting?
Kirkinsb
Brushless All The Way!
Kirkinsb's Avatar
01.25.2012, 08:57 PM
I checked the 5t and it was 2 samplings per second. All other settings were stock. No punch control, etc... If you set the sample rate much more than 2 per second, you won't get the entire run into the logging memory....you will only get 7 minutes or 14 minutes. Most guys at the HPI baja Forum are all pulling anywhere from 200 to 240 in their Castle Creations bajas....so, I think that my data is right on the money with it being around 220ish.
My 11lb revo (GPSed at 62mph) is also on 2 samplings per second....and according to the data log pulled a max of 106.5amps. All other settings are stock.
So assuming Castle Bajas pull 230ish...it makes sense to me that a 10lb truck would pull about half the amps as a 28lb truck. Seems just about right to me.
A ten pound muggy pulling 200amps!!!...what the heck motor is in it?!?!?!
All I can say is at a sampling rate of 2/second, all other settings stock, I was pulling 106 in my 11lb revo and 225ish in my 28lb 5t according to the Data log from each mamba XL2.
You have to agree that if he was just blipping the throttle and already getting 240amps...something seems odd when compared to results I have...plus all the other baja owner who have converted to the XL2 and 2028 motor who are getting about 230ish amps as well. That is all I know. a 10 lb muggy pulling 240 amps just blipping the throttle seem high....with the little bit of data logging experience I have had and read about.
Don't know if this helps...I may try a higher sampling rate...but that sucks because I would only get 1/3 or 1/2 the run into memory. Do you think 2/second sampling rate is sufficient?
Was that muggy pulling 200ish using a MambaXL2? let us know.
data log rate
RC-Monster Mike
Site Owner
data log rate - 01.26.2012, 11:40 AM
Kirkinsb - 2 samples per second data rate explains your low numbers for sure - you are simply missing the microsecond peak currents that happen. In my experience, the peak draw will ramp down very quickly once the car is rolling - a 200+ amp spike could be down to 120 amps within the same second. 2 samples/second frame rate will not show this, though. I understand that a higher frame rate will result less log time, but it will also yield higher data resolution so you can see more detailed data, albeit for s shorter time. Besides....do you really need to log the entire run every time? Please maximize your frame rate, gather some data, and report back. You can always change the frame rate back afterwards, but I think you will be surprised at what you see.
Also, while the Baja is a larger, heavier vehicle, it also typically is used under a higher voltage and will have less traction than an overgeared Muggy(4wd) with large, heavy tires. On the surface, logic may say that a car that is half the size will draw half the current, but in truth, there are many variables that will quickly dispell this logic. Also, a throttle "blip" can be no different than a full on drag race launch, but over a shorter time period. The actual peak current happens over a very short time period(1/10 second or even less) so it does not surprise me to see 200+ peaks on a heavy, overgeared 4wd monster truck.
magicald - The highest log rate will give you the highest resolution. In reality, the average draw is typically fairly low, but there are microsecond peak currents that are very high. Personally, I have only used the highest available frame rate, as I normally am only logging data when I am trying to dial in a setup or test a component(battery, motor, etc.). The highest resolution will provide the most information in a short period of time. The beautiful thing is that you can change the frame rate! I think it is wise to maximize the frame rate occasionally to properly visualize the truest data, but there is nothing wrong with a lower frame rate to gather more general data over a longer period.
In my opinion, you simply can't draw any accurate conclusions from data logged at different frame rates - logging at a low frame rate will mask peaks.
Kirkinsb
Kirkinsb's Avatar
01.26.2012, 02:17 PM
Good info..makes sense.... I will try the highest frame rate one of these days and see what happens.... Also good info about how higher voltage and current affect each other. Sounds good. I am just glad the XL2s seem to have the bugs worked out. They perferm great. Thanks
Pdelcast
Pdelcast's Avatar
01.26.2012, 03:02 PM
Just for everyone's benefit--
The ICE datalogger (used in the XL/XL2) actually samples the current several times during each PWM cycle (synchronously), and then keeps a running average of the results. The samples are then written to flash memory at the programmed "sample rate."
So the sample rate is only the rate at which the averaged samples are written to memory -- not the rate at which the controller samples the current...
Make sense??
Patrick del Castillo
President, Principle Engineer
Kirkinsb
Kirkinsb's Avatar
01.26.2012, 05:08 PM
Make sense??
Ok, so my readings at 2/second are probably fairly accurate? And I am not missing any huge amounts of data by not using the 5/second setting? Yes/No? Hmmm, interesting. Is their much benefit to having the data written 5/second as opposed to 2/second since it is averaged? thanks Patrick.
brian015
brian015's Avatar
01.26.2012, 05:46 PM
No, your readings are more averaged than if you had the data written at a faster rate - so the real peak of the spike is averaged with lower currents on either side of the peak giving a lower average current written to the memory. Writing data at a faster rate should include less averaged data - so truer to the actual curve.
I think.
freddy
02.12.2012, 09:43 AM
This is the data im getting with my 1717 savage XL, no cogging and motor and esc temp covered in plastic was around 60f.
Great motor, my only complaint is that my run time compared to the stock savage with 1515 is halfed(ore more) :) Def a power hungry beast
