Pdelcast
Pdelcast's Avatar
01.26.2012, 03:02 PM
Originally Posted by Kirkinsb View Post
Good info..makes sense.... I will try the highest frame rate one of these days and see what happens.... Also good info about how higher voltage and current affect each other. Sounds good. I am just glad the XL2s seem to have the bugs worked out. They perferm great. Thanks
Just for everyone's benefit--
The ICE datalogger (used in the XL/XL2) actually samples the current several times during each PWM cycle (synchronously), and then keeps a running average of the results. The samples are then written to flash memory at the programmed "sample rate."
So the sample rate is only the rate at which the averaged samples are written to memory -- not the rate at which the controller samples the current...
Make sense??
Patrick del Castillo
President, Principle Engineer
