08.14.2013, 06:59 AM
Check connections. Looks like a phase is having an issue.
08.14.2013, 09:44 PM
Is this a new setup or a new problem in a proven setup?
Like Arct1k said solder connection could be the culprit.
If this is a previously working setup, is it possible you could have overheated the motor? I've had motors start to stutter after being overheated and losing magnetism. If that is the case the motor is toast.
