Serum
Serum's Avatar
09.25.2006, 10:41 AM
too bad they want to score with a motor/controller combo. A controller would do, and according to them, the selection of the motor takes so long.
I hope they will be more sensible in kv value with those monster.. the 7700 kind of surprised me.
Sower
Sower's Avatar
09.25.2006, 01:59 PM
I'm actually a little dissapointed in my Mamba Max. Although it might just be my setup. I'm running the 5700 in a Lightning Stadium 10 which is a little heavier than many 1/10 scale vehicles. And it's 4wd. My problem is the heat build up.
I have (2) 3100 mah Polyquest 3c lipos in parallel to give me 6200 mah, and I'm running a 13 tooth pinion. Timing advance is on lowest and I have a fan on the motor and esc. I raced for the first time this weekend and it shut down from heat. I measured it at about 185 (esc). They say it's safe up to around 200, but I don't like it. I ordered a 12 tooth pinion, but I'm not convinced it will make a huge difference.
I think I might go to a Neu motor that runs more efficiently. I don't know - anyone have any ideas or help for me. I'm a little bummed.
