Procharged5.0
Procharged5.0's Avatar
12.28.2006, 04:07 PM
The spool works in both the T-maxx and the E both are the same. The spool can only be used in the rear diff (unless your doing mud bogs then front is ok too).
Base upgrade would include aluminum diff cases (Great Assembly RC or similar) and aluminum diff cups (Fastlane Machine, Kippster, Maxximizer).
If you can afford it the Robinson Racin Diff Gears are nice to have too.
The next step up involved moving to an 1/8 scale buggy diff. Buy the Unlimited Engineering Ultralite diff set-up with the 6-spider or 8-spider diffs (8's are stronger yet) or the Fastlane machine "combo diff/bulk" for 1/8 scale diffs.
If money is no object buy the Unlimited VBS system w/8-spider diffs. Strongest combo on the planet.
BTW, I use the FLM cups, FLM gears, GA cases in my truck. No use on it yet so I can't tell you how much abuse it will or won't take.
