Well, if high C rates aren't needed, you could try emolis if you want the 3.7v nominal voltage. They are metal cased like M1 cells, charged just like lipos, and are rated for 2.3Ah but only at ~12C IIRC. If you use a 2p arrangement, you can get discharge currents of ~60A, which is fine for smaller vehicles, or maybe higher voltage/lower current setups.
