ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
04.18.2007, 10:58 PM
thanks shocker!
i honestly have no talent in this hobby... at least none compared to others on here that do some amazing transformations (hint: look for one 'transformer' on here as an example! :003:). i appreciate the kind words though!
the custom light kit was done by maxxlights. i also had to track down a pico switch from dimension engineering to enable my radio to turn the light system on and off. the lights are tough, and guaranteed not to break (or if they do, i have to take a picture of the carnage and send it with the broken lights back to them, and they'll replace it free lol).
i honestly don't remember how much i have wrapped up in it (i purposely don't keep track of that for any of my trucks... talk about a 'shocker'! :eek: ). the clod stock kit was around $250, the JPS kit was probably at least that much, the JPS wheels (which is where i went wrong... the center hub, which is where all the lateral force is held, is only about 2mm thick. and it's aluminum, so it bends easy) were probably $200. at one point i did have 2 esc's, one to power each motor, and a battery for each too. when i turned it into a crawler last fall i found i only needed the titan to power the 2 motors. last fall i added a $35 hitec 645 servo, 2 lathe motors that were about $30 total, the 4 channel radio and light kit. then $50 for a JPS rear bumper, and some adjustable motor mounts, tranny mounts for the suspension links and pinions from rc4wd.com. prolly other stuff i'm not thinking of at the moment, lol.
Eflite Blade 400 heli on 3s
