crazyjr
crazyjr's Avatar
04.25.2007, 08:15 PM
Originally Posted by BrianG
Crazyjr: The bad part about running the BEC that hard is the it sin't even attached to the heatsink. It's hard to tell, but it looks like the regulator for the MM is actually on the other side of the board. So, the heat is being leeched away using the PCB traces and into the FETs, and then into the heatsink. Not exactly a direct connection and that heat is just making the FETs not run as well since FET current capability gets derated with higher heat.
I didn't know it wasn't connected, I stand corrected. I have run on a 5700 T4 and 3s for over 30 minutes and it never thermaled. The 12 cell one was a 9XL in my G2R and it would be kind of jumpy after about 30 seconds, I assumed it was the bec cutting off and on and quit mediately till i got my koolpower ubec
