05.03.2007, 01:08 AM
The bore reducer I got from Mike looks like it is aluminum. So, make sure your pinion grubs screws are in tight and use lock-tite because if the shaft spins inside the bore reducer, it will wear it and make the pinion wobble. Trust me, I know from experience...
