Cajun
05.03.2007, 09:24 PM
Originally Posted by BrianG
Good job man! That's a very different setup!
What did you end up doing with the tranny (lock into second, keep 2 speed, etc)? Also, is that Hammered finish paint I see? I love that stuff - it makes a nice hard finish.
Thanks Brian! The idea was to get it as compact as possible. I want to be able to use a stock body without it being pushed out. The batt tray should accompdate up to 16 cells. The only drawback to the configuration I see is that I'm going to have to lengthen the ESC to motor leads by a few inches.
I locked the tranny into 2nd using your method. That is Rustoleum Hammered finish paint. I love that stuff too, nice and hard plus it hides all the imperfections better than any other spray paint I've found.
I have a couple of little things coming from Tower to finish the setup, then I'll be ready to run.
