zeropointbug
Z-Pinch racer
zeropointbug's Avatar
05.04.2007, 02:37 AM
Originally Posted by AAngel
I don't have my Quark yet, so I've never seen one up close yet. Aren't the battery leads just soldered to a pair of holes in a PCB?
Anyway, are those the caps that are needed? The 300uf 35v ones linked to on ebay. It would seem that the price isn't bad for 200 of them.
You could also use these, if you are using 4s LiPo. They are 25v/820uF, your choice.
Yup, those are the caps you need, they are the 330uF/35v.
The wire leads go through a hole at the end of the case, which is plastic. The wire solders adjacent to the pcb board. HERE is a pic.
