Cajun
05.04.2007, 08:54 AM
Originally Posted by suicideneil
That is a different approach to mounting up the electronics, but I kinda like it- everything has a specific place, its not just stuck down where-ever.
Good work there dude, now go finish the kitchen before the missus starts complaining....
Thanks! I just sat down with it and my foam core mock ups once I had all the nitro stuff striped off and started thinking about where everything would fit. I also wanted to be able to access everything without having to remove a bunch of brackets, as well as making everything as compact as possible while using only the stock mounting holes and tabs. I also didn't want to modify my chassis incase I ever wanted to go back to nitro on this one. It took some thought and several paper versions, but I finally figured out how to make it happen. I can access, remove or work on any part of the truck without removing anything I added. I guess it helps that I'm a designer/architect by trade and spend a lot of time thinking about how to make things work conceptually then how to make it happen in the real world.
I actually started the kitchen last night, so I'm good there too. But your right, gotta keep the little woman happy so my RC addiction can get fed. :D
