neweuser
neweuser's Avatar
05.04.2007, 02:42 PM
Originally Posted by Serum
Nope, go for a 50 percent throttle 'in air' on the speed you are approaching the jump, that way it should stay flat.
that is correct, you don't want to keep it on full throttle after you leave in the air, but maybe half or so. When you keep on the throttle, it will start to make the truck travel going backwards. If you brake in the air, your truck will nose dive, you can correct your problem by just tapping the brake to level her out in the air.
