05.09.2007, 05:06 PM
Yes, cats do have a tendancy to be sick just where you dont want them to; even if you pick them up and put them in the kitchen to be puke up a hairball they will still run into the livingroom and make a mess on the carpet. Cant say the goldfish give me that trouble though....
Cant wait to see how peoples rigs perform post 'upgrade'. Im thinking that in order to get reliable results for comparison (without caps / with caps), that something like a steady run up and down for 10-15 minutes should be done. Measure temps, run time, capacity remaining in batts etc using an eagletree and ICE charger or whatever- plot some graphs with the data. Then solder on the caps, and repeat the test, driving up and down in the same manner. Plot the results again and compare them to the original set; if all goes according to plan then you should get some pleasing results. The key is obviously to minimise the variables as much as possible in order to conduct both tests in the same way, as far as is possible/ practical.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
05.09.2007, 07:09 PM
That really would not be reliable and/or useful, as there are too many variables (including driving).
You really have to do it by feel, and general eagletree results... the average voltage might be a little higher, but the main results will occur inside the controller, FET switching efficiency, and cooler running (apparently), and more reliable running.
I have my hopes mainly for cooler running, and more reliable, which matters most.
