05.20.2007, 07:38 PM
If you don't change the gearing, you will go faster. If you are already happy with the speed, use the calculator to find the pinion you need to achieve the same speed with the higher voltage.
And yes, current will go up assuming that everything else stays constant. However, you may find your runtime going up simply because you aren't on the throttle as much.
