The Mamba Max motor is considered an "s" size motor, and just doesn't have enough to power a heavier MT (~10lbs). You could get it to work if you geared it VERY low, but then it'll only go like 15mph. For decent speeds, ~35mph+, most get an "xl" motor. The turns count will depend on what voltage you plan to use. The MM ESC can power these larger motors if geared right.
