Chapito
05.28.2007, 11:37 AM
Originally Posted by gixxer
I got my mount a few days ago too. The only issue I had was the holes not being tapped deep enough. I didn't have a tap so I just cut off a little of the screw. other then that the mount looks great and let me finally finish my 8t.
The two screws that are no longer being used for the Batt. box work perfect for the rear diff/motor mount. Also, you may want to consider getting some longer ones for the front diff mount; with the spacer in place there are'nt alot of threads penatrating with the stock screws. I went from 1/2 to 5/8 in. long for the fronts.......................
