G-Maxx Steering Question -
07.12.2005, 10:40 AM
I need some help. I just built a G-Maxx truck. I am using the G3 Race suspension with the G2 X-Brace chassis. I am running Ingedy piggyback shocks. I have a Novak Brushless motor.
Love the truck, but I have a problem. My steering linkage is hitting the bottom of the shock where it mounts to the L-arm on both sides. Sitting normal, its fine. If the suspension is depressed, it hits. This only happens when its turned a little one way or another. Strait is fine. I have the stock turnbuckles with stock ends.
What can I do to correct this? I have the stock Steering bell crank setup, with aluminum posts. I would like to upgrade the entire setup to aluminum, but I want to fix the problem first.
Please help!
:eek:
07.12.2005, 05:51 PM
You could use a suspension limiter? (fuel tube inside the shocks) or an external wire..
07.12.2005, 07:14 PM
Would you be able to post a picture?
Site Owner
07.12.2005, 08:55 PM
A picture would be helpful. Perhaps you have the turnbuckles mounted incorrectly or something that a picture would clear up.
Pictures of my G Maxx -
07.12.2005, 09:59 PM
Thanks!
07.12.2005, 10:01 PM
2
07.12.2005, 10:03 PM
3
07.12.2005, 10:04 PM
4
07.12.2005, 10:06 PM
5
Site Owner
07.12.2005, 10:07 PM
Thanks for the picture. If possible, could you take a picture with the wheels off from the rear of the truck (get a close shot of the front steering set-up from the rear perspective and no wheels). It is a little difficult to see the trouble in the above pictures. Also, make sure the turnbuckle is mounted on the bottom of the sterring knuckle. A quick tip that may halp is to reverse the lower shock mounting screws(put the nuts on the inside, towards the cvd).
07.12.2005, 10:09 PM
6
Site Owner
07.12.2005, 10:11 PM
Sweet truck, by the way!
07.12.2005, 10:18 PM
Thanks!
07.12.2005, 10:20 PM
7
8
