07.13.2005, 03:15 AM
This may also be off topic, but on my Maximizer cups I had to modify the yoke of one driveshaft a little. You had the same, Mike?
I'm looking forward to the 3Racing stuff.
07.13.2005, 03:29 AM
You mean the shaft didn't fit thru the hole?
07.13.2005, 03:33 AM
Yes, if you mean this small shaft with the thread that goes thru the hole in the output shaft of the diff.
Just by one mm or so. I thought I mentioned this, but have checked and found nothing. Possibly I mentioned it in a conversation or pm.
Site Owner
07.13.2005, 09:08 AM
I didn't make any mods on my Maximizer diff. It fit right in fine and everything bolted up fine.
07.13.2005, 09:39 AM
Hmm, the cup itself was a perfect fit. But on one side the output pinion shaft was not sticking out enough. Was reproduceable, and I checked against the stockers. Strange!
Site Owner
07.13.2005, 09:53 AM
I used the stock driveshafts on mine. I had no such issue. ;)
07.13.2005, 11:11 AM
Stock driveshaft here, too. Issues on both diffs, equally. Had a really close look, no mistake on my side, I believe. Both bearings were properly in place, but one output shaft was not long enough. Implies either a different geometry of the cup, or a horrible assembling job. I dunno.
07.19.2005, 03:09 PM
Hey RC-M Mike, On page 3 of the revo hopups the diff cups for $15.50 are the 3Racing cups aren't they
07.19.2005, 03:21 PM
Yes, they are. And the 3R external diff cases are on page 2. (they cost less than 30 bucks, wow)
Site Owner
07.19.2005, 09:09 PM
Yes, they are the 3Racing cups and cases. I am working on getting many more 3racing items in stock(as soon as they come in stock from my distributor).
07.19.2005, 11:20 PM
Thanks. I will be making an order soon
