crazyjr
crazyjr's Avatar
06.12.2007, 06:47 PM
Originally Posted by Heyitsme
Ya I havnt orderd the motor yet but will tonight for sure. So you think 4600 will be good? what kind or speed can you get off the 4600 and 3s lipo with or around 15 thru 18-86 gearing?
Edit: And how bout with 7 cell nimhs what kind of speed?, I decided Im going to order a 7 cell IB nimh, and Maxamps 3s 6000mah Lipo
And did it seem more controlable on the 4600 motor with the 11.1 volts?
Thanks
If it were me I'd go 4600, the lower KV will make it heat up less and run more efficient. You may not be able to use the 8000 mah 3S as its big BIG, I just got a 5000 maxamps pack in both 2s and 3s. The 8000 2s will fit only a little modification, the 5000 3s will fit perfectand weigh less than a 6 cell pack
