NiCad
R/C Racer
NiCad's Avatar
06.17.2007, 12:51 PM
Originally Posted by IBJAMMIN
Yes the knuckles are stock. :)
I assume that the stock knucks are plenty stout. I use the stock knuckles on my rc18 with alloy c hubs seems to be the tightest fit, yet remaining smooth operation. Is this a similar case here?
Later,
NiCad
Owens Racing™
CRT.5 B/L
Detta ST B/L
RC18(diggity LHO) B/L
Detta Buggies Brushed Bashers
Dafni
Dafni's Avatar
06.17.2007, 12:53 PM
Thank you Skellyo!
IBJAMMIN
IBJAMMIN's Avatar
06.17.2007, 01:16 PM
The Proline buggy 2.2 wheels have to much of an offset to fit they hit the lower a arms the 2.2 Asc truck wheels need a little triming on the ribs inside the wheel to clear when turning I have not ran the larger truck tires because I dont think the steering servo can handle them I burned up a servo with the Jaco RC10t foams already to much grip I guess?
I have broken 2 rear hubs and cracked the dust shield on the front C hubs the steering knuckles have held up fine though that and the brittle ball ends are the only weak spots I have found in the CRT.5. :)
NiCad
R/C Racer
NiCad's Avatar
06.17.2007, 02:00 PM
How often you run yours IBJAMMIN?
Owens Racing™
CRT.5 B/L
Detta ST B/L
IBJAMMIN
IBJAMMIN's Avatar
06.17.2007, 02:08 PM
On average about a pack or 2 a week?
I just saw on Nitrohouse more upgrade part's are starting to show up for the CRT.5 White wheels and wing's a new CNC chassis and some new high downforce wing's are avalable. :027:
NiCad
R/C Racer
NiCad's Avatar
06.17.2007, 02:22 PM
The wings are nice looking.
Just ordered the following........the pinion size was he smallest hardened he had instock. Figure a couple extra mph won't be all bad. ;)
Product ID: 5mmmod1pinion
Product Name: 5mm bore, mod1 pitch pinion
Quantity: 1
Unit Price: $12.00
> > > pinion size - mod1 -5mm : 16 tooth hardened steel (+$4.00)
Product ID: rcmcrt.5mm
Product Name: CRT.5 Electric motor mount adapter
Quantity: 1
Unit Price: $35.00
Product ID: RCMBReducer
Product Name: Bore reducer for 5mm bore pinions
Quantity: 1
Unit Price: $5.00
> > > Bore reducers : 1/8" shaft
Now need to get a the battery. 3s lithium, thinking 3800 APOGEE MAGNUM. I run the 1000 mah packs in my B/L Detta ST.
Owens Racing™
CRT.5 B/L
Detta ST B/L
IBJAMMIN
IBJAMMIN's Avatar
06.17.2007, 09:52 PM
I went with the 4000mah 3s Maxamps pack and would recomend the 5000mah pack or a 100amp constant pack the 4000 at 80amp constant gets a little warm and has melted the shrink wrap a little on the end? I believe it needs a little more amp capacity? This was with the foams running on the street road racing and geared to run near 60mph speeds though.:005:
NiCad
R/C Racer
NiCad's Avatar
06.17.2007, 11:38 PM
I will def take the advice and go 5000 mah or more, nothing like a little extra run time. Did you happen to check weights of parts for balancing the chassis? I am the type a few grams not going to show itself in a 4 lb truck! ;)
Owens Racing™
CRT.5 B/L
Detta ST B/L
nitro28
06.18.2007, 12:00 AM
I have one of the 6000mah 2s lipos from maxamps and it is quite nice. Its interesting how many people from one18th.com are now on this site. I love my rc18t, but I am hoping the crt .5 will be a little more stable at full speed.
NiCad
R/C Racer
NiCad's Avatar
06.18.2007, 12:14 AM
FWIW I have been wrining my Detta St out with the permax and quark. I am sitting on GRP 30mm foams. This thing is sooooo stable at speeds it is unreal. I plan to get some alloy shocks and then lower the stocks for speed runs. Also got a 3s to try been running the 2s packs. I am saying 35-40 mph right now prob close to 40 mph, I say this I ran a car down on my road speed limit is 35. I caught it with ease. As well the permax makes hardly any heat. I got some gearing to try on the 2s first.
anyway for a stable excellent 1/18th ride look at the Detta ST, it is def similar to the CRT.5. This is why I had to have the CRT.5, my 1/8th scale buddies will not be running this thing over as easy as the ST! That is if they can even catch the CRT.5 when it hits the dirt.
Owens Racing™
CRT.5 B/L
Detta ST B/L
silentbob343
06.18.2007, 05:40 AM
heh I just want something that can handle a powerful BL setup without stripping diffs/pinions/etc. The minquake and detta are good to a point, but I think a .5 CRT will be my next RC.
BlackedOutREVO
06.25.2007, 02:55 AM
anyone thinking of using those new 30's series proline wheels and tires? they look sweet! and should IMO be perfect size, just need a bigger wing and this thing should look SWEET!!!!!!!!
i think i may be back on at a crt .5,, that or another onroader to race, but i NEED a basher, already have the 5700kv and mm esc waiting for something lol... so i mite
IBJAMMIN
IBJAMMIN's Avatar
06.25.2007, 11:05 AM
The larger wheels and tires may be a problem with the mini steering servo? I fried 1 servo running the Jaco Associated truck foams I'm not sure if it was a bad servo or too much traction with the foams that killed it? I replaced the servo and have not ran the foams and there has been no more servo problems. :)
BlackedOutREVO
06.25.2007, 01:25 PM
hmmm idk, was it a hi tec?
those do that, futaba servos dont do that, there much better quality
IBJAMMIN
IBJAMMIN's Avatar
06.25.2007, 11:20 PM
Ya it was a Hitec The next servo I think I'm going to try is the Futaba S9550 low profile std size servo it's about a 1/2" shorter the a STD servo and with 83ozin torque and .11 speed @6v should be much better then the Hitec.:)
