06.19.2007, 11:10 AM
Are lipo's like nimh in respect to when the charger shows they are finished charging you have to use them right away to get the best performace, or can i use them two or 3 days latter ?.
06.19.2007, 12:50 PM
You can use them three days later and they will still be almost fully charged, and there won't be a power difference after three days. However, it's best to keep Lipos at about 3.8v/cell when not in use (storage), so keep that in mind.
06.19.2007, 01:03 PM
Im new to this lipo stuff how can tell if each cell is 3.8 & will it hurt if i store them higher than 3.8 ?. I'm assuming i can just measure the pack voltage as a hole ?.
I just figured out i can use the balanceing tab to measure each indaviduel cell.
06.19.2007, 01:12 PM
I usually just run my vehicle for about 1/3 of the normal runtime. That typically sets the voltage right around 3.7-3.9v per cell. Yes, you can measure the pack as a whole and divide by the number of cells, but this assumes the pack is balanced.
06.19.2007, 01:14 PM
Does it hurt if you store them with more than 3.8 per cell ?.
06.19.2007, 01:17 PM
I can't remember exactly what happens when you store over 3.8v, but I do know it is better for the cell. I don't think it will explode or anything.
06.19.2007, 01:21 PM
So after your last run of the day what is your rutine for storing them ?.
06.19.2007, 01:45 PM
Is it bad if they are stored for a couple days with no charge? I ask because I am waiting for my charger in the mail, and surprisingly, the battery came fully charged, so I ran it.
06.19.2007, 10:21 PM
Anyone know? Sorry for the thread hijack...
06.19.2007, 10:43 PM
A couple of days is ok. A week, maybe. Longer; run it down to 3.8v/cell.
06.19.2007, 10:52 PM
I wouldnt leave it for longer than you need to. I forgot to throw a little charge in one of mine once and it was fine a few weeks later. But it wasnt 3.0v/cell to start with either. Its best to store them with a little voltage in them. but you will probably be ok as long as you didnt run it down to far.
to make it...
or break it...
Silent...But Deadly
06.19.2007, 11:28 PM
I ran it down until about 12.5 volts. I hope the charger come within the next two days or so, so I don't have to start freaking out about the battery.
06.22.2007, 04:33 PM
what should the volatage be on a 4s 8000 pack be when fully charged ?. Thank's
06.22.2007, 04:41 PM
4.2v per cell.
16.8v total.
to make it...
or break it...
Silent...But Deadly
06.22.2007, 04:46 PM
Originally Posted by jhautz
4.2v per cell.
16.8v total.
Thank's thats what i thought. My charger shut off before it got to 16.8. I just called maxamps & they said sometimes that can happen. He said it was safe to put it back on the charger . I guess it might have false peeked or something. I did balance them before starting.
