pumpkinfish
06.25.2007, 02:01 PM
Great replies. Thanks!
I guess I should qualify my run time concerns. We run three 5 minute quals and a 15 minute Amain and 10 min Bmain. How long does a pack take to charge? I would like to go, practice and run the quals, then race the mains. In case I make the Bmain and bump up, I want enough on tap to race tha A. I usually make the A but you never know if you have a bad day or brake something. So if a pack charges quickly, then I will have no problems charging between quals and mains. If it takes a while, I will need to budget two packs then pick the electronics after they are selected.
Does anyone know if the motor mount Mike makes if compatible with the Inferno 777? If so I am golden.
