jnev
jnev's Avatar
08.25.2007, 12:11 AM
The MGM and Quark both have there weakness. The Quark can't run 6s even though it says it can, and it has overheating problems. But if you don't run 6s or plan to, it is a great choice if you can do the heat mod. I'll try to find the link for how to do it.
The MGM seems to have reverse/braking problems from what I hear. However if you don't use reverse or have it programmed, then it doesn't matter.
Which Neu are you talking about specifically? The one you have written in your signature would run great in an E-Maxx. I can't help with the gear meshing part as I don't have an e-maxx. Hope the previous info helped though.
E-Maxx King
08.25.2007, 12:32 AM
Ive learned alot so far. Im going to get the neu 1y. Unless the 1950/6 lehner (MM) is in stock??? lol I that pretty much everything?
Heres a list of the setup Im going to be running. (14 cells) I like the MM pc programing, but the quarks sleek design. Hmm???
Neu 1y $280.00
RCM Neu Endbell Cover $ 7.50
RCM Idler Gears $ 28.00
RCM 72mm Dogbones (2) $ 24.00 (Where do i get the drive cups?)
RCM Strobe Slipper Kit $ 32.00
RCM Ofna 51T Spur $ 7.50
RCM 1/8 HB Pro Diffs $130.00 (do I need bearings for the pinion gear?)
RCM Gold Plugs 5.5mm $ 10.00 (How Many Male And Females?)
FLM 1/8 Hybrid Bulkheads $140.00
FLM Bulkhead Braces $ 18.00
Kershaw Designs 22T 43mph $ 20.00 (Way Over Priced! Man that Gay)
UE Servo Saver Gen. 4 $ 84.00
Hitec HSC-5955 333oz $115.00
3.3 Knuckles $ 20.00
3.3 Turnbuckles $ 10.00
$1206.99
