08.29.2007, 04:36 PM
Originally Posted by Serum View Post
what about a larger spur?
Genius Serum, if you guys are running the 66 tooth emaxx gear you can go up to the 72 t maxx gear. Then run a larger pinion and have the same ratio. Or convert to mod 1 spurs and pinion chices are much better and the gears last longer.
