CC BEC - this might have a lot of potential......
VintageMA
VintageMA's Avatar
CC BEC - this might have a lot of potential...... - 08.30.2007, 11:33 PM
The one you bought is just a regular UBEC - the one made by Catle Creations claims to have an adjustable output voltage if programmed using the CastleLink USB cable.
I wonder if Mike will start to carry this?
I can think of multiple reasons to use a variable output voltage. Use one BEC to drive the receiver and servos, and have a second variable BEC to control the fans on a setup - if you need a little more cooling you just crank up the fan speed by raising the output voltage on the fan BEC........
“Everyone has a right to be stupid; some people just abuse the privilege.”
