Batfish
Batfish's Avatar
07.22.2005, 02:53 PM
I'll go out on a limb and assume he meant 'windshield', which would mean cutting a hole in the windshield of the body for more air flow.
Joe
Electronics run on smoke... if you let the smoke out, they stop working.
Shadow350Z
Shadow350Z's Avatar
07.22.2005, 03:17 PM
yeah i guess thats it ill cut my windshield l8r 2day to see
  Send a message via AIM to Shadow350Z
Serum
Serum's Avatar
07.22.2005, 04:03 PM
who needs a windshield anyway...
Shadow350Z
Shadow350Z's Avatar
07.22.2005, 05:50 PM
lol when i get my Crowd Pleazer 2.0 for my Maxx im nto gon cut the windshield
and its gonna have light buckets and lights!
J Cates
07.22.2005, 08:31 PM
What in the *&%#@ is a WINDSCREAM?
hv-maxx-kid
07.23.2005, 02:42 AM
Must be a English terms, but yes i am referring to the 'wind shield'..
Shadow350Z
Shadow350Z's Avatar
07.23.2005, 03:40 AM
i put a hole in the windshield and ran it and it didnt thermal
but i twisted my rear shafts so i have to get CVD set soon
Serum
Serum's Avatar
07.23.2005, 03:46 AM
A little air works miracles every time..
tomato
tomato's Avatar
07.23.2005, 07:30 AM
I've been able to go with a 14 tooth pinion by using a body with out the window insert.
drumgod828
07.23.2005, 12:51 PM
To help keep things cool; sometimes I use a can of compressed air to rapidly cool things down. If you turn the can upside down and the spray. The liquid gas rapidly cools that area and then evaporates. So you don't have to worry about the electronics.
Sneeck
RC-Monster Custom
Sneeck's Avatar
07.23.2005, 03:34 PM
Rapidly cool a hot motor for example down is a bad thing and can cause damage. If you want to cool it but still be safe, use a fan.
  Send a message via MSN to Sneeck
drumgod828
07.23.2005, 04:23 PM
Sorry I should have been more clear. I don't take a motor so hot you could fry an egg on it and make it as cold as ice. Instead I constantly moniter it and spray a little here and there. I only do it on the outside. When you allow small delicate parts to go from extremes in hot and cold, things can break.
Doing this is a lot like having a heat sink.
Serum
Serum's Avatar
07.23.2005, 05:02 PM
you must know that something that might feel hot and burning on your hands is only 117 degree fahrenheit. this is a 'no sweat' temp for electronics.
i personally would not use something to cool electronics of fast. This might cause a loose contact on the print where the transistors/fetts are soldered on..
