09.05.2007, 09:50 AM
The screwdriver is simply a metal rod. Any induced voltage would be VERY VERY small (in the nano volts), and screwdriver "coil" is oriented the wrong way for an induced voltage to spin it. Also, the A/C case is sheet metal, so that is going to block any magnetic fields from the internal motors.
I don't think I could even try to duplicate it with anything else since this was very random/arbitrary and just happened to do this.
