jhautz
jhautz's Avatar
09.10.2007, 01:00 PM
Its actually pretty easy....
Here it is in a nutshell.
Turn on transmitter, plug in battery, Hold transmitter on full throttle, turn on switch, wait 10 sec for 3 beeps, move to full reverse, wait for beep, move to neutral, wait for 2 beeps.
now you are in programming mode.
now move the throttle to full reverse, wait for beeps, move back to neutral, wait for beeps. (you just selected option 1 for setting one.) move it to full reverse and back to neutral again for option 2, reverse & neutral again for option 3 etc…
Once you have done this ( for example reverse to neutral 5 times to select option 5) now pull the throttle to full forward, wait for beeps, now back to neutral. (You just set setting number one and it ready for you to set setting number 2)
Use the same method for option 2 (full reverse to neutral the number of times corresponding to the number of the option that you want) then full throttle forward to set it, and go to setting number 3.
And so on until you are done.
Once you get thorugh it one or twice its actually pretty easy.
to make it...
or break it...
Silent...But Deadly
