09.10.2007, 09:22 PM
I can only see the wire/pinion proximity being a problem with larger pinions like Mod1 18T. It looks like there is quite a bit of room otherwise, and if the motor wires are anywhere near as stiff as most others, there is VERY little chance of them flexing and touching the pinion.
I wouldn't mind trying one out but I'd like one with a KV closer to ~1800. Even on 6s, the total rpm is less than 30k, which means it would have to be geared up a bit for the desired speeds. I really want another Quark and they're only good for 5s. Hmmph.
