Dab a little on each end of the pin, then dab some on the input shaft between the gears. I usually do one gear at a time, then stand the shaft on it's end in a vise to let it soak in until it dries. Then turn it over and do the other gear.
Don't apply any on the outside of the gears or it will interfere with the bearings.
