09.28.2007, 01:08 AM
Check to see if your front and rear driveshafts are different length. Often you can use two of the front (shorter) shafts. The outrunner will most likely be longer than the ctr diff. For an 1/8 scale buggy you will need a big out runner, most likely 40+mm diameter and 60+mm long. Kv and battery choices will be critical to obtain the desired speed.
