10.01.2007, 10:09 AM
Like I said, you should be ok, but keep an eye on it. Also, you might want to pick up some foam padding for the tray. 1.8" thick craft foam works very well. Comes in sheets of 11"x8.5", is easy to work with, cheap (< $0.50 IIRC), and is available with a sticky backing (enough to hold it in place while being fairly easy to remove). I get mine at Wal-Mart (craft section).
