lutach
lutach's Avatar
10.08.2007, 06:24 PM
Programming is simple. I usually do the A Mode Choice first and then I do the rest. I do the following:
I enter programming and I pull the trigger to brake 3 times and I know I'm at the "CAR" mode one way. I turn the ESC off. I then turn the ESC to make sure it recorded the Mode Choice. Afterwards I just skip Parameter A by pulling full throttle and do the rest of the programming. Just make sure you don't loose count. It was painfull when I first got a MGM controller, but it is easy now.
