rschoi_75
Certified Spaceball
rschoi_75's Avatar
02.18.2008, 01:28 PM
Thanks supra. I got some good runs in yesterday and this morning. I couldn't be happier.
This buggy is noticeably more powerful and the new CC software update runs the Neu very smoothly. At the end of a 15 minute run on 5s 4800mah lipos, the motor was 102*F and the MM was 98*F. The lipo was even cooler at 87*F, and ambient temps are around 65*F outdoors. All in all, this buggy has very happy electronics. I must also note that running the novak 2700uf cap does keep the esc much cooler than without it. So thanks for the tip fellas.
rcm xt8
rcm xb8
rcm crt.5
center diff
fwd4g63
center diff - 03.07.2008, 11:05 PM
hi, just a quick question. what did you do to modify the center diff? just curious. i noticed with the instant power of the brushless system it onloads the front tires and then the power is gone waisted on the tires spinning in the air.
thanks
rschoi_75
Certified Spaceball
rschoi_75's Avatar
03.11.2008, 06:57 PM
Hi, try some heavier oil in your center diff. It will prevent the front from unloading like you describe.
rcm xt8
rcm xb8
rcm crt.5
diff lube
fwd4g63
diff lube - 03.12.2008, 12:34 PM
yeah i tried a lot of different weights in it. the heaviest oil i have found is the kyosho 500,000wt. it helped and im sure in a race scenario it would be a lot better. i just bash though so i went back to forward only and it wheelies more which sucks as far as trying to keep it on the ground, but i did quit splitting the front tires. thanks for the tip though
03.12.2008, 12:58 PM
30k traxxas oil does the job for me...
oil
fwd4g63
oil - 03.12.2008, 01:20 PM
yeah that had nothing for me. like i said i used 100k oil and then 500k fluid and it didnt do much better. it is brushless on 5s though
rschoi_75
Certified Spaceball
rschoi_75's Avatar
03.12.2008, 06:44 PM
what's your rear diff filled with?
also, maybe reduce the start-up power some how? what esc are you using?
rcm xt8
rcm xb8
rcm crt.5
Hydrodancer
Hydrodancer's Avatar
03.14.2008, 10:05 PM
It sounds to me like the oil your running is too thick. The rear is getting full power and is causing your front end to lift and unload. If you thin out the oil the front wheel will stay more planted and pull the buggy through corners.
The only other options are to lighten up on the lead finger or move/add weight to the front to keep it down.
rschoi_75
Certified Spaceball
rschoi_75's Avatar
03.20.2008, 04:13 PM
Yeah, that's what I figured. Thanks cadima. much appreciated.
rcm xt8
rcm xb8
rcm crt.5
Jammin PBS conversion!
rschoi_75
Certified Spaceball
rschoi_75's Avatar
Jammin PBS conversion! - 04.15.2008, 12:06 PM
A little update....
I recently got the jammin pbs conversion for my buggy. It feels like I've gained some more steering which is always helpful. The quality of the parts are very nice as well.
ID:	4420   Click image for larger version
ID:	4421   Click image for larger version
rcm xt8
rcm xb8
rcm crt.5
rchippie
rchippie's Avatar
04.15.2008, 12:38 PM
I thought about getting this conversion kit fot my jammin. But i was'nt realy sure it would make a difference. My buggy seems to have a lot of steering with the original setup. your buggy looks great .
REAL MEN RUN BRUSHLESS
