Mike_D
Mike_D's Avatar
10.06.2007, 08:00 PM
Well here is my conversion. LSP Pro with Feigao 8XL, MM Esc, 12 3300 Nimh's ( crappy ones BTW ), Hitec high torque servo, Hellfire axles with 17mm hex adapters and wheels, also Hellfire shocks. So far it seems pretty fast. The motor does not get above 120 degrees but the Esc get to about 150 - 160 degrees. I am using a 46 tooth spur and a 14 tooth pinion ( mod 1 ), i think i may drop down to a 12 tooth to see if that helps temps at all. Now it's time to save for that Lipo pack i've been talking about.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
HB Ve8 x 2
jnev
jnev's Avatar
10.06.2007, 09:57 PM
Looks very nice. I should be receiving my LSP-R by the end of next week.
I noticed that all of the new Feigao motors are black... is this something new? Because I think they look awesome that way.
entjoles
10.06.2007, 10:05 PM
looks great!!
a few teeth on the pinion should help temps. , you could also put the esc. in front of the Rx for more airflow
also fwiw: i would cut some fuel line and slip it over the wires under the driveshaft, or use some shoe goo to stick em down
oh... i see in the last pic its under the brace
crazy4wdracer
10.14.2007, 09:01 AM
the lsp is a great truggy, I think that you will be very happy wth it, btw nice conversion.
BL-Power
BL-Power's Avatar
10.20.2007, 07:25 AM
Great looking conversion! Mine will be finished next week
Does somebody know if the GPM shocks for the LST2 will fit to my Lightning?
Thank you for your help and sorry für my bad english
 Send a message via ICQ to BL-Power
