ESC question
david lamontagn
ESC question - 10.24.2007, 11:30 PM
Can i use a boat controller in a truck?? If i use the stock mechanical brake, what's the difference between a boat and car controler?
Thank you!
David
cart213
cart213's Avatar
10.24.2007, 11:56 PM
Yes, you can. I've got a CC Barracuda 125 in my MGT, using the mechanical brakes. I honestly can't tell any difference between the performance of the Barracuda and the Mamba Max. The Barracuda has far few tuning options, of course, but for a basher like me, it's no big deal. I'm sure there are differences in the start profiles and acceleration profiles, but the biggest software difference is the lack of brakes on the Barracuda. If you're using the mechanical brakes, though, this shortcoming doesn't matter.
Plus, the lack of braking duties means there is far less stress on the controller, so it doesn't get as hot. Mine hasn't gotten over 125F yet, even though it doesn't have a heat sink. This is using a Neu 1512 2.5D/F and 6s2p A123 cells.
david lamontagn
10.25.2007, 12:07 AM
OK cart213, the main reason why i ask this is because i'am to convert my revo into brushless and i've order an MGM Compro 16018 with a Neu 1515, 1Y.
And i want a spare ESC in case where the MGM died.
On my revo, i use the stock mechanical brake, so if i go with the baracuda, you can tell me that t's a solid choice??
But please tell me about the cogging with castle and Neu combo Lot of guys here tell that Mamba Max controler cog like crazy with Neu, but is the barracuda run great with the Neu motor??
thank you!
David
cart213
cart213's Avatar
10.25.2007, 12:34 AM
The Barracuda runs great with the Neu. NO COGGING! I've got a MM and had cogging issues with the same Neu motor.
Also, before I bought the Barracuda, I called CC to ask their opinion. They said it would work, but they cautioned that the Barracuda has a more aggressive start profile than the MM and would be more stressful to the drivetrain. So far, though, I haven't had any drivetrain troubles on the MGT.
david lamontagn
10.25.2007, 07:03 AM
OK , i've take a look on the castle web site, and they said that we can now program the Barracuda with the castle link, and he have a brake profile programable.
But what about the fact that he don't have heat sink
