Originally Posted by lincpimp
Hey griffin, do you think that this would work with 2 aveox motors? I have a pair of 27 series 200kv motors that I wanted to run on an emaxx tranny on 5s thru a quark 125.
Make sure that wires from motor to motor are shorter then from motors to ESC.
I am assuming that motors are identical in terms of Kv and construction. To check how close they are to be identical, solder them together and spin the shaft by hand. If it spins freely with no hiccups and second motor follows then you have pretty good match, otherwise one of the motors will be dumping that difference into the heat and creating challenge for the ESC.
P.S. We do not have propellers here and vehicles with props do not have differentials between props either, just wheels and mud :)
