11.07.2007, 11:08 PM
Ok, I cut and welded an emaxx cvd to the correct length for the front driveshaft. I also filled the center diff with 50k traxxas diff fluid. Runs much smoother now and the spur is no longer hitting the front output shaft of the center diff. I also got my modded MM back from griffinru today and will install that along with a hitec 645mg servo. Should be a good basher now, everything is working well.
