Thread Tools Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
sikeston34m
sikeston34m's Avatar
11.16.2007, 02:17 PM
She's still in rough form, got some tidying up to do. But I couldn't resist seeing it run. I strapped in 4S Lipo setup (2S2P each at 10,000mah) and took it outside.
She runs pretty good, but there is much tweaking to be done. It will cog on startup if I am too quick with the throttle. If I ease into it, it starts fine. After I let it roll up to about 10mph or so, I can stab the throttle and it slings gravel and tops out quickly. Top end on this configuration is about 30 to 35mph. She needs more voltage! It's pulling a really high gear. More voltage will increase the motor torque dramatically and broaden the rpm range. It will also raise the top end speed alot.
I'm having a programming issue with the Quark also. I can't seem to get it to go into Advanced programming mode! I feel like I need to set it to "outrunner" mode. This will increase torque and make it start much better.
It doesn't matter which trigger sequence I use, (min-Max......or Max-Min) it slips into Basic Programming mode. What am I doing wrong?
Here's a pic with the Lipo's in place. I'm going to try 6S2P A123 next. Gotta get the receiver pack out.
