rchippie
rchippie's Avatar
11.16.2007, 08:15 PM
Originally Posted by speedy View Post
Hi !
One of my friends has a konverted inferno st truck with a feago 8xl and a mm esc and runs it on 4s 5000mah fp packs, and he has some cogging issues if he floors it from a standstill what can cause this ?
He runs a 16/48 gearing combo and has the lvc set to 12,5v.
Is the pack fully charged ?.
REAL MEN RUN BRUSHLESS
speedy
11.16.2007, 08:46 PM
it coggs even with the wheels of the ground !! :(
ssspconcepts
ssspconcepts's Avatar
11.16.2007, 09:55 PM
Are the pinion and spur too close and/or tightly meshed together?
speedy
11.17.2007, 12:28 PM
no it coggs even without any pinion when you go from reverse to full forward and if you let the motor turn at maby 100rpm and the peg the trottle.
ssspconcepts
11.17.2007, 03:22 PM
Bud...I think something is broke. I have an 8XL and a Mamba here and just for giggles I put it in my FLM MAxx with 3S...no cogging. I even tried several different pinions...no cogging. I even reset the Mamba to factory defaults and still no cogging.
I know you said you were running 4S with a UBEC...but that shouldn't make a difference...
phildogg
phildogg's Avatar
11.17.2007, 04:12 PM
would a loose connection or bad solder joint cause this? might not hurt to check.
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
