rootar
rootar's Avatar
11.16.2007, 11:38 PM
I read about the front bones coming out and i took mine apart already and put little o-rings and foam blocks in the cups to keep the bone centered and they FAR from coming out when to have the wheels turned to the stops, unlike stock which got pretty loose. Thanks for the heads up about the axle pins i already had to do that to my little mini-lst2 beacause i would snap a stub axle and loose the pin.
btw i weighed my truck as you see it and im getting just a hair under 5 pounds. is this heavy or light compared to everyone else's LS10s ?
yours is different tashpop i like it, how does it weigh in with all those A123 cells?
