ssspconcepts
ssspconcepts's Avatar
11.19.2007, 07:10 PM
It is 2 per phase. You add the 2 wires per phase together. It helps deliver all the AMPs to the motor. My Schulze has 2 positive and 2 negative and a big 6mm connector at the end and Jeti SPIN 200 has 2 wires per phase like the 22418.
So my understanding is that I should put both leads from each terminal into one female connector...right?
